07 Fit - New Vid of the AB XFL15 flex on Pg 4
Update time. I decided to cut up the 4th order, it just took up too much space. In doing so the 4 10's got damaged, they were inverted and the surround gasket foam stuck to the mdf. So it peeled away part of each even trying to be careful. So I stopped at a local car audio place today and picked up a new sub, it's the American Bass XFL 15" D2. This thing is a beast, I am going to make a new baffle for my old 4.4 cu/ft ported box (33hz) and use that for now. Here are some pics of the sub.
american-bass-xfl-15-coil_zpsb43725de.jp
american-bass-xfl-15-basket_zps256dc9dc.
Got the 15" in my old box and it's pretty serious for a single sub. I didn't hammer on it too hard just yet but it seems to have those 4 10's easily matched. We'll see once I crank on it a bit more. It's in my old ported box, 4.4 cubes @ 33 hertz. I had to mount it to the front of the box though, since the brace was in the way to mount it up top. So I stuck some MDF over the 4 10" holes and screwed it down. I cut a quick hole and tossed it in. I'll see how it does in this box and decide if I want to go bigger or smaller when I eventually make a box just for this sub. I think the size will be about the same though, might adjust tuning a bit depending how testing this box plays out. It's nothing special to look at right now so I didn't take a pic yet.
  • 2 months later...
  • 3 months later...
The American Bass 15 is still kicking hard, this sub is awesome. I'd love to upgrade to an 18 of some sort eventually just to move a little more air but they are all so expensive unless you settle for a basic Parts Express model which wouldn't hold a candle to the 15.
I'd like to upgrade everything again really but being a baller on a budget, it's no so easy. If you were in my shoes, what would you upgrade? Here are my current system specs. I am thinking some OFC wire might be in order, not sure what else.
  • Head Unit – Pioneer DEH-X7500S
  • Front Door Speakers –6.5″ MB Quart Components FSB216
  • Rear Door Speakers – 6.5” Phoenix Gold Coaxial (HU Power)
  • Amplifiers – Rockford Fosgate R125-2 on the MBQ’s / MB Quart ONX1.1600D on the Sub
  • Subwoofer - American Bass XFL 15″ Dual 2 Ohm in 4.4 cu/ft tuned to 33hz
  • Battery/Wiring – Xs Power S680 / 2 AWG DB Link CCA / Scosche Distribution Block
  • Sound Deadening – 40ish sq/ft FatMat in the hatch. I would have liked some higher end second skin type deadening but the budget was not there.
  • 2 months later...
