07 Fit - New Vid of the AB XFL15 flex on Pg 4
Hello, thanks for checking out my build. I decided to stick a system in my Honda after years of not having anything but stock audio. I just don't have a lot of funds for high end equipment, so pretty much everything is budget equipment. I don't really have any goal other than to eventually hit 150db for as cheap as possible, we shall see how that turns out. For now I am just enjoying having some tunes again.
Video Added Below --- Post # 3
Honda-Fit-Sport_zpsdc7ac52e-1_zpsafc0442
As of right now I've got the following gear installed. (You can click the links for more pictures)
This puts me at about $300 total audio cost so far. I need to upgrade the sub amp, install an amp on the highs, do the big 3, install the rest of my deadener along with numerous other small projects. I will add some pics to this thread when I do updates. As of now here are some pics of the gear I've already got along with some pics of the box build.
MBQ Comps. (tweeter is up high)
fit-deadener-final_zps359353cd-1_zps4409
Some deadener I put on the hatch the other day.
Box Build Pics
Wish I had a nail gun, drilling and screwing took forever. You can see the 7" brace in the middle of the box.
fit-subs-lanzar-max10d_zpsdbc9201e-1_zps
fit-subs-lanzar-max10d-4_zpsf690ec16-1_z
Don't mine the hideous port, I didn't have any paint handy so I gave it a sharpie treatment for now. I'll be making a proper amp rack once I have a permanent amp. I also need to install a terminal cup for the sub box, but I can't find one I like yet. I may do bolts, not sure.
Any questions let me know.
As of now even with only 400 watts the 4 10's get down, I know they can take a lot more though. I will post a video soon as well.
Not bad if your hatch is roughly the same size as mine, 09 fit I have a nice box design for 2 12s you can use if you want.
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Thats a cool little build you got goin on
2008 Black Chevy Tahoe -Murderedout/ 2/4 Belltech drop/26" U2-55's/ HID's in fogs and headlights/G5 tails1 - BC35001 - C1100.42 - SA ZV3 18's6 - 8" SA Neo Pro's2 - FT1-SE Tweets
not bad at all for the budget! nice work!
If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
I finally installed the speaker wire bolt connection setup I got when I built the box originally. I didn’t want to bother with a terminal cup because I intend to install 10-12g wire with ring terminals eventually. I just bolted the bare copper down for now. This low power setup wouldn’t benefit much from more anyway. I also cleaned up the amp wiring a little bit, plus it looks much better without the speaker wiring hanging out of the port.
Inside the box.
Cleaned up the wiring around the amp. I also utilized both connections on the amp, so two pairs of the thin speaker wire feeds the 4 instead of just one.
Current shot.
Thats all for now. More updates soon...
Added some more deadener. Only had enough to do the passenger side wheel well/hatch area.
Bare - aside from the one lone piece I stuck on before taking this shot.
After a couple sq/ft...
Finished off the last 10 sq/ft of fatmat I had. Need to order another 50sq/ft or so.
Thats all for now, more updates soon.
  • Who's Online   0 Members, 0 Anonymous, 4798 Guests (See full list)
