certifiednut Posted January 7, 2013 Report Posted January 7, 2013 i would do the form fit corner box if you are set on sealed. Because if you are going to go through sealing off the trunk, you might as well build the box a bit larger and throw in a 4" aero. Sealing off isn't a big deal. I'll use the IB baffle as a template for the new baffle, then seal the edges with foam. FYI, a proper ported box for this sub would be 3x as big as the sealed one. The idea here is to save weight and have a very flat bass curve. If it isn't hard to seal off, i would do that. For some reason i forgot you have built 60 enclosures for that mustang, sealing ff the trunk should be super easy by now. these orphans aren't going to feast on themselves
