brad4021 Posted January 10, 2013 Report Share Posted January 10, 2013 i used 1" on my box but it has a large window. we have used 3/4 with no issues also. And if your windows are small enough like those pictures then i would say 1/2" would be ok but make sure you use foam gasket tape and screw the heck out of it. And from the posts above, i believe lexan is more flexible than plexi because plexi is not very flexabe at all unless it is heated and bent. And dont quote me on this but i do not believe lexan is repairable if scratched. plexi can be torched to clear the edges and can also be wet sanded and buffed out if it is ever scratched depending on the type of plexi you use Link to comment Share on other sites More sharing options...
Joshex Posted January 10, 2013 Author Report Share Posted January 10, 2013 Thank you for the input, I figured it would have to make some gasket. My main question now is, what sort of mount/securing would be best? Never worked with this stuff before so I have no clue if one screw type would be better than another. I was thinking doing like Steve did and doing the thread nut method maybe? 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here Link to comment Share on other sites More sharing options...
brad4021 Posted January 26, 2013 Report Share Posted January 26, 2013 there are a million different methods that can be used. I screwed it right into my mdf with a bunch of wood screws on my box but i was going right into the mdf so i was able to run 2.5" screws. make sure you pre drill and definitely slightly over size your plexi piece so the screws do not grab and crack the plexi. on inserts like you showed usually use t-nuts or something similar in the inside and then just bolt on. this method is nice because you can remove the insert and remount it multiple times without worrying about stripping out the mdf. just make sure you drill everything straight down so it all lines up right and not at an angle. hope this helped a little Link to comment Share on other sites More sharing options...
ThreehundredC Posted January 26, 2013 Report Share Posted January 26, 2013 i used 1/2 inch and it was good to go Link to comment Share on other sites More sharing options...
Joshex Posted January 28, 2013 Author Report Share Posted January 28, 2013 Thanks for all the help guys. I will probably attempt this with the next month or two. 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here Link to comment Share on other sites More sharing options...
brad4021 Posted January 28, 2013 Report Share Posted January 28, 2013 good luck and if you have any more specific questions pm me and i will try and point you in the right direction. Link to comment Share on other sites More sharing options...
