IKnowImLost224 Posted January 10, 2013 Report Posted January 10, 2013 I feel pretty confident about this box but I wasn't sure about the port ratio. Also when I cut the wood for the 45's how do I know how wide to make the pieces?
Skrilla Posted January 11, 2013 Report Posted January 11, 2013 You didn't put in the displacement of the sub, displacement of the bracing, or how many common walls. 2 HDC3 18's AQ2200D
Guest Posted January 11, 2013 Report Posted January 11, 2013 port ratio is fine. but you need to add in what Skrilla said. # of common walls is the most important, since it can change the values around the most
IKnowImLost224 Posted January 11, 2013 Author Report Posted January 11, 2013 I will add the woofer displacement. What would be the number of common walls? It's going to be a L port on the left side of the baffle.
CleanSierra Posted January 11, 2013 Report Posted January 11, 2013 3 port walls Im not the one you want to try to troll. Just a fyi for you.
IKnowImLost224 Posted January 11, 2013 Author Report Posted January 11, 2013 Okay I will try to update the info tomorrow and get a new pic up. Anyone have any info on cutting the 45's?
Skrilla Posted January 13, 2013 Report Posted January 13, 2013 You will be around 30hz... You forgot to put how many common walls. So where is says "# of common port walls" type in 3 2 HDC3 18's AQ2200D
IKnowImLost224 Posted January 13, 2013 Author Report Posted January 13, 2013 Ty sir, that's updated in the new post!
