Rca Grounding?
so I'm planning my moves for when it gets warm (April or so here in MD) and I've got some engine noise coming through my speakers and I figure its my HU ground (good place to start since its using the factory ground wire, not a chasis screw). I figured I'd ground myRCAs too so my question/verification is I should use the same grouding point for the radio ground and the RCA's right?
also, when ground the RCAs, I get the impression that I can just use ??guage wire, strip it, make a loop, solder it into that loop, put the loop over the end of the RCA and plug it into the head unit? or should I just find a ring terminal? would a 16 or 18 guage remote turn on type wire do the job for them?
thanks!
no need to solder, to ground the RCA you can just put one end into the rca and ground the other side to the stereo chassis
oh, its that simple? just strip enough to go into the rca jack along with the cable and ground her to the actual head unit? Brilliant, thanks M8!
heres a lil titorial on how to ground rca's i did http://www.stevemeadedesigns.com/board/ind...showtopic=15452 thats the way i do it and most others hope this sums it up a lil bit better
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
  • Who's Online   0 Members, 0 Anonymous, 5031 Guests (See full list)
