IKnowImLost224 Posted January 14, 2013 Author Report Posted January 14, 2013 Purple I believe I had it set at 3.7 cubes in winisd. I'm gonna try to work with the size of it tonight. Could the port be a problem? It's 12.5 x 3 x 30. I am new to building boxes but I thought you get a higher output with some of the bigger boxes.
purplesyrup Posted January 14, 2013 Report Posted January 14, 2013 Purple I believe I had it set at 3.7 cubes in winisd. I'm gonna try to work with the size of it tonight. Could the port be a problem? It's 12.5 x 3 x 30. I am new to building boxes but I thought you get a higher output with some of the bigger boxes. You do, but you also can really narrow down the frequency response. can you post a pic of you graph showing the hz on it/?
IKnowImLost224 Posted January 14, 2013 Author Report Posted January 14, 2013 Purple I believe I had it set at 3.7 cubes in winisd. I'm gonna try to work with the size of it tonight. Could the port be a problem? It's 12.5 x 3 x 30. I am new to building boxes but I thought you get a higher output with some of the bigger boxes. You do, but you also can really narrow down the frequency response. can you post a pic of you graph showing the hz on it/? Yessir, I work till 5 then have some things I gotta get done after work. Ill try to mess with it and get the pic posted tonight!
IKnowImLost224 Posted January 15, 2013 Author Report Posted January 15, 2013 There ya go purple. 4 different box sizes all with the same tuning.
purplesyrup Posted January 15, 2013 Report Posted January 15, 2013 There ya go purple. 4 different box sizes all with the same tuning. I would choose the yellow, 2.0 cubic feet, but will still question how 2.25 and 2.5 would look Also, this seems to be graphing a lot smoother than yesterday, did you fix a parameter or something?
IKnowImLost224 Posted January 15, 2013 Author Report Posted January 15, 2013 Under signal it said series resistance, I figured it meant series coil resistance and it was at .1 so I changed it to 4.
IKnowImLost224 Posted January 15, 2013 Author Report Posted January 15, 2013 Now how come when I tune the box to 33 Hz it peaks at 38? Should I tune it lower and increase box size? I wanna get this thing loud!
IKnowImLost224 Posted January 15, 2013 Author Report Posted January 15, 2013 What about something like this?
