mdegen Posted January 14, 2013 Report Share Posted January 14, 2013 How would you wire a sub to .5 ohms? 1 ohms etc.. Link to comment Share on other sites More sharing options...
Noel989 Posted January 14, 2013 Report Share Posted January 14, 2013 More info Impedance on voice coil/s Single or dual Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
Noel989 Posted January 14, 2013 Report Share Posted January 14, 2013 Or visit the12volt.com Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
mdegen Posted January 14, 2013 Author Report Share Posted January 14, 2013 I already know 2 ohm which I have 2 dc level2 12"s dvc wired to I'm just curious as how to wire different ohm loads Link to comment Share on other sites More sharing options...
Noel989 Posted January 14, 2013 Report Share Posted January 14, 2013 You have 2 12" d2? Amd your currently wire to? Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
Sonic Posted January 14, 2013 Report Share Posted January 14, 2013 Read up on resistance in series, parallel and series-parallel. Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2013 Report Share Posted January 14, 2013 I already know 2 ohm which I have 2 dc level2 12"s dvc wired to I'm just curious as how to wire different ohm loads you are making no sense. so you have two dual 2 ohm woofers? Link to comment Share on other sites More sharing options...
mdegen Posted January 14, 2013 Author Report Share Posted January 14, 2013 I already know 2 ohm which I have 2 dc level2 12"s dvc wired to I'm just curious as how to wire different ohm loads you are making no sense. so you have two dual 2 ohm woofers? yes and they are powered by a JL audio HD 1200/1 amp Link to comment Share on other sites More sharing options...
08tahoe Posted January 14, 2013 Report Share Posted January 14, 2013 Basically when you wire in series the ohm load doubles and when you wire in parallel you cut the ohm load in half. So for example a dual 4 ohm sub in series would wire to 8 ohms and a dual 4ohm sub in parallel would wire to 2ohms. Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2013 Report Share Posted January 14, 2013 here is the only *safe* wiring config you can do. meaning, not .5 ohms. Link to comment Share on other sites More sharing options...
