XS Power
You don't NEED an upgraded alt, but one wouldn't hurt either
D5100 to replace your up front one should be good enough. If you want a 2nd also anything bigger than a d975 would be excessive unless you plan to upgrade later
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
Atleast with my experience it should. I ran 1500w off of a d1200 and only dropped to 13.8v
Run an XS Power, yellow top etc up front for starters. After that add batts in the trunk so you can handle more watts. You will reach a point where you need a H/O alt as well.
I think ima settle for 1700 for now x]
Maybe worry about upgrading later on, but for 1700 i should be good with 1 D5100 up front under the hood? :D Awesome. Also, what gauge wire should i run?
Would 0 GA make that much of a difference at this wattage?
Always run 0 gauge. Bitches love 0 gauge!
