Trunk/hatch Corner Box: 1/2 Fiber Glass/mdf.
Man, I really like how this is turning out. I like you using the radiator, they're not seen that much.
Thnx...But He had it when he came to me so I get no "credit" for choosing equipment on this one.
I just have the task of fitting it in there, making it pretty, and sound good.
More pics...and more to follow.
Posted Image
Posted Image
Posted Image
How I "suspended" this piece w/ out permenantly attaching it.
Posted Image
Figuring out just where the lil arc/box will go
Posted Image
Posted Image
Taped up/mocked up
Posted Image
Posted Image
Big hole for the G5 to play through into the other chamber and move the Radiator
Posted Image
Posted Image
Posted Image
More after the upload.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Looks like you have your hands full! is it going to get carpet?
HAHA ur tellin me. Covering this thing? :blink:
Yup Blackish/greyish/carpet-ish.
dude thats badass you are pretty creative
Baylor University
Accounting
Thnx Tex.
More pix.
Had to shave this tiny lil notch. (har har)
Posted Image
Adding some pulled apart chop mat to the bottom b4 I attatched the mdf base piece
Posted Image
Add resin and tap out bubbles till your brain starts to come out ur ears.
Posted Image
(white stuff still VISIBLE?=BAAAAD)
Posted Image
Tap tap tap....
all gone. ;)
Posted Image
Mdf base in and started glassing the corners in.
Posted Image
I know some air is trapped in the lil "nook" outside the edge of the mdf since it's not a perfect copy of the inside of the glassed part but it will be pleeenty strong.
Posted Image
Posted Image
Coutersink for the screws so they are in flush...careful not to overtighten and crack the glass...no washer used here-I've done it like this b4 so no worries.
Posted Image
Posted Image
Few more divits for screw heads...
Posted Image
The toolio I use to make the divits/countersinks
Posted Image
Here's where that BIG hole was...now it has a piece of mdf to glass to and I taped it from the inside and will just glass over the tape, pull the tape when it's dry, and glass it THOROUGHLY from the inside.
Posted Image
From the inside...
Posted Image
Posted Image
More uploading.....
the shaved part....(har har again)
Posted Image
How i temp attached the top pieces
Posted Image
Deck/speaker clearence
Posted Image
Kinda hard to see what's goin on here, but basically just showin how the "arm" that moves when the trunk lid is raised/lowered hit the top of the top-piece I had intended to be where it is in this pic..so I just dropped it down about an inch and it's back in business.
Posted Image
"Arc/pocket" Ver 2.0
Posted Image
Posted Image
Posted Image
The underside...but is it big enough?
Posted Image
Posted Image
Checkin it in car
Posted Image
Posted Image
Posted Image
Wide enough? yes.
Posted Image
Deep enough? Nopes.
So I chopped the bottom off that lil arc I had made and grafted it onto the bgger tape/carboard version to form a lil double bump pocket...
Posted Image
Posted Image
Had to remove the bottom of Pocket V 2.0
Posted Image
Posted Image
New and improved
Posted Image
Posted Image
Flipped over and ready to start glassin er up form the inside.
Posted Image
I AM REALLY LIKEING THIS BUILD AND YOU ARE DOING A GREAT JOBS LOOK O SO SICK
96 IMPALA SS
Pioneer DEH-P8600MP H/U
Pioneer TS-C160R 6.5"
Pioneer TS-D690R 6x9"
JBL GTO755.6II
Stinger spdh-10 cap
100sqft. Fatmat
AQ 3500d
18" FI BTL 7cuft 35Hz
Thanx.
Last of the pix...till 2morrow when I can run some tools.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Bandages coming off.... :blink:
Posted Image
Posted Image
Inside the pocket with the tape/carboard coming out....
(YES I'M WELL AWARE IN THIS PIC IT IS/LOOKS LIKE JUST RESIN ON THE TOP BUT I GLASSED OVER IT THOROUGHLY!....cuz I know Timmay would try to "BUST ME OUT" on that kinda ish!)
Posted Image
About 1/8"-1/4" inch "wiggle room" in there once the tape and cardboard was out....I guess I didnt get any pix of it but I glassed the shit outta this pocket from the outside/top just like on the inside so It's nice n sturdy and it filled in that lil 1/8"-1/4" space inside the pocket so the walls are "flush" again.
Posted Image
Checking the airspace finally...........1.33cft NET. I was shooting for 1.0cft net, but this is close enough.
Posted Image
The packing peanuts are STILL inside in this next pic to account for displacement.
Posted Image
You can kinda see the glass inside the top of the pocket on the inner walls.
Posted Image
Adding trim rings.
Posted Image
YES.....I knew they would overlap like this...
Posted Image
Posted Image
They go under the knife tomorrow...then the glass/filler comes out.
Posted Image
This here is a template.....I might end up doing sompin "way cool" w/ it....or not If I run out of ambition/time/patience to hear this thing.
Posted Image
