I just bought an 04 Chevy Blazer LS 4x4 and im thinking about putting a small lift kit on it. By small I mean 2, possibly 3 inches max. The main reason I will be lifting is to get a little bit more clearance as I ski, love camping, and I mud from time to time. I have never owned my own truck nor worked on anything related to lifts/drops, etc.
I guess first of all, what are some of the possible complications of puting a lift on a truck like this? it is pretty narrow so I figured becoming more prone to roll would be a primary issue. Is there anything else I need to consider buying to support the lift?
The main questions I have are what are some brands to look for/stay away from? How much should I be expecting to pay just for the parts? How saavy do I need to be to do the install myself (I have a few family friends that have done an airbag system before that I wired, but never a straight lift)? Am I looking at more work/a higher price to do this because it is a 4x4 as compare to an RWD vehicle? If so, by how much? Finally, how much of a difference will 2-3 inches make on my vehicle in terms of looks, performance, and the tire size I can fit on it?
I just need general advice, and I have no idea where to even start so I figured I'd ask the guys that have helped me answer so many questions in the past. If you guys think this is a dumb/stupid idea, just let me know. Same goes for the opposite. Thanks...
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
Just get the 2.5" rough country that the best kit for your blazer go check it out and then check out blazer forumn
Alright thanks I will
Subs/Amps: TBD
If you want to go cheap get some shackles to lift the rear and crank your torsion bars. Yes cranking the bars puts wear on your front end. But its a cheap lift. I have shackle/tbar lift on my 2000 Blazer ZR2 and haven't had any issues. SImple enough one or two guys can do it in a couple hours. Like the others said check out blazerforum.com im on there as well. Good luck with your build! Like to see pics!!
What size tires do u plan on running??
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
I had a 96 with 31s and just cranked torsion bars..
1999 grand prix gt
  • Who's Online   0 Members, 0 Anonymous, 1770 Guests (See full list)
