AI James Posted January 23, 2013 Report Share Posted January 23, 2013 i owned the same model amp for a while, i got it in a trade from a forum member in 03ish it was powering a couple XXX 18's in my explorer for a week or so before selling it for a grand back then. it was a 1200-1500 dollar amp back then at retail and was class AB as well if i remember correctly. NOT a 10k RMS amp Link to comment Share on other sites More sharing options...
purplesyrup Posted January 23, 2013 Report Share Posted January 23, 2013 well here is a modern day 5k I bet you that thing cant even clamp 3k AND probably has one 4ga input so if you did clamp 3k, it would be melting the 4ga wire This statement is not true. My saz-3500's were tested from Sundown with 4 guage wire. I was told as long as the wire is short you can run ample amount of current through them I understand what you mean, but its based off of length, most people have 15-20 feet of power wire runs Quick Reference This table shows the amount of current flow which will cause a 1/2 volt drop in a 15 foot run of cable. Many people consider 1/2 volt to be the maximum acceptable voltage loss in a system's main power wire. The 'total amp power' is the total maximum unclipped RMS power output‡ of all of the amplifiers combined. It is based on 60% efficiency (for class AB amplifiers) and a battery voltage of 13.8 volts. ‡ For all of the calculators and tables on this page, unless otherwise noted, 'max power' is the RMS power output when the amplifier is on the threshold of clipping. Max Total Amp Power from a 15 foot 4ga run 4 awg 131 amps class d 1355 watts Link to comment Share on other sites More sharing options...
fox_racin4 Posted January 23, 2013 Report Share Posted January 23, 2013 Anddd howany people who run 5k+ have a single batt in the front? So... That being said the run would be less then 5 feet, i hope. 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
AllanLuberda Posted January 27, 2013 Report Share Posted January 27, 2013 i like the oldskool amp, but werwy Link to comment Share on other sites More sharing options...
cc_audio Posted January 27, 2013 Report Share Posted January 27, 2013 I don't think its particularly old school, definitely not a $600 amp anymore. Its an IFB-2340dB, which is two 1500W amps strapped in one case. 54" long. Very rare though, I'd hit him with an offer. Would be fun to have. It's all gone! The Celica Build Feedback If I buy something from you, DO NOT USE FEDEX! Link to comment Share on other sites More sharing options...
