load test with amp?
Ok so I wanted to know if its bad to go get my front & rear battery load tested at AutoZone with my amp hooked up, the past few days its been 6-15 degrees f when I go to start my car the lights dim all the way when I try to start it,
Front battery is a interstate acid, rear is a shrunkien bt-120 with 0 gauge connected in the front right to the alternator post where it drops off the power.
Just want to know if I should unhook the amp if it matters
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
That's how the rear gets power, so it shoulnt be bothered during a load test I assume.
No one?
Really no answer?
Really no answer?
takes 5 seconds to unhook an amp. just do it if you're seriously that worried.
I thought you had to remove the battery?
Yea but 30 mins to hook it back up-_-
  • Who's Online   0 Members, 0 Anonymous, 2967 Guests (See full list)
