Cynicalbass210 Posted January 26, 2013 Report Posted January 26, 2013 Okay, so should I get another kinetik 2400 and keep a single run of wire going or get the kinetik later and do a second run of wire all around with toolmaker di's?? I will be using knukoncept kollossus wire. Not too sure which would benefit more over the other. Any opinions appreciated! 1991 Nissan PathfinderMechman 240A altAll wire 100% OFC 1/0Kenwood KDC-X497Pair of Kenwood Tweets/Pair of Rockford P1 5x7s9ft3 vented box ~32hz2 AQ HDC3 copper coil 18sSAZ-3500 @ 1ohm Powerbass ASA 200.239 sq. ft. damp pro.Kinetik 1200&2400(x2)
MECHMAN Posted January 26, 2013 Report Posted January 26, 2013 The second battery will make a much larger improvement in performance than adding another run. 1-888-MECHMAN www.Mechman.com [email protected]
Cynicalbass210 Posted January 26, 2013 Author Report Posted January 26, 2013 The second battery will make a much larger improvement in performance than adding another run. Right on, thanks for your input! Now that I think about it that does make sense. My goal is to get my hands on another one within the next couple weeks. I can get a brand new one shipped to my door for 285 shipped. Or should I be alright buying a used one? 1991 Nissan PathfinderMechman 240A altAll wire 100% OFC 1/0Kenwood KDC-X497Pair of Kenwood Tweets/Pair of Rockford P1 5x7s9ft3 vented box ~32hz2 AQ HDC3 copper coil 18sSAZ-3500 @ 1ohm Powerbass ASA 200.239 sq. ft. damp pro.Kinetik 1200&2400(x2)
MECHMAN Posted February 6, 2013 Report Posted February 6, 2013 If you have any more questions call 1-888-MECHMAN or visit http://www.mechman.com/ OR http://billetalternator.com 1-888-MECHMAN www.Mechman.com [email protected]
