Tsimp01 Posted January 27, 2013 Report Share Posted January 27, 2013 New the the forum but have so many questions! I'm having a problem with my valves on my ZUZU, my set up is fronts individual and my back together. When i air up they work fine. When i release the air with one switch (no matter which one) the truck pancakes! Help please. If pics are available i would appreciate that as well. Link to comment Share on other sites More sharing options...
Carbon Posted January 27, 2013 Report Share Posted January 27, 2013 Pics would help, also a more detailed description of what you need help with. Link to comment Share on other sites More sharing options...
fox_racin4 Posted January 27, 2013 Report Share Posted January 27, 2013 Probly have some wires touching somewhere 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
Tsimp01 Posted January 28, 2013 Author Report Share Posted January 28, 2013 Well I don't exactly know what to take a pic of! Like I said when I raise the truck it's fine every switch does what it's suppose to. But when I drop it one switch drops the whole truck... Link to comment Share on other sites More sharing options...
Tsimp01 Posted January 28, 2013 Author Report Share Posted January 28, 2013 Would having all the power wires from my switches be linked together? Same with the ground? I followed the wiring all the way and there is no wires touching anywhere Link to comment Share on other sites More sharing options...
sprkn_ranger Posted January 28, 2013 Report Share Posted January 28, 2013 Has it always done it or did it just start doing it? Sounds like wiring to me too. Maybe the leads are touching in the switch box? Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/ Link to comment Share on other sites More sharing options...
Tsimp01 Posted January 28, 2013 Author Report Share Posted January 28, 2013 I hadn't thought of the leads touching ill try that too. I've followed all the wire and it's all clean no touching in that aspect Link to comment Share on other sites More sharing options...
Tsimp01 Posted January 29, 2013 Author Report Share Posted January 29, 2013 Checked the leads and that's not the problem either! I'm puzzled! I've even cut the power down to one set of valves after lifting the truck and it still drops the whole truck??? And everytime I drop the truck it releases ALL the air from my tank as well as the bags. Link to comment Share on other sites More sharing options...
sprkn_ranger Posted January 29, 2013 Report Share Posted January 29, 2013 You said you have side to side in the front and just up and down in the rear right? And the whole truck drops when any switch is hit to dump? What kind of valves? Is it a manifold type valve setup or individual valves at each wheel? Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/ Link to comment Share on other sites More sharing options...
Tsimp01 Posted January 29, 2013 Author Report Share Posted January 29, 2013 Yes side to side in the front and just up and down in the back. Got the air bag it valves individual, no manifold. And yes the whole truck drops when I hit any one switch. Link to comment Share on other sites More sharing options...
