ok i just checked them out briefly and it says that its Linkable to another SAZ-3000D for up to 6000 watts @ 2 ohms so this setup would be good then. i can wire at two ohms just like my speakers would be and also go down to .5ohm... i think im starting to get it haha
3000 x 1 watts @ 1 ohm
1600 x 1 watts @ 2 ohms
800 x 1 watts @ 4 ohms
0.2v - 6v adjustable input sensitivity
10 Hz - 350 Hz Frequency Response
>90 dB S/N Ratio
4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
10 Hz - 60 Hz adjustable 24dB Subsonic Filter
0 - 180 degree adjustable phase shift
0 - 18 dB adjustable bass boost with 45 Hz center frequency
Wired Remote Control unit included
300-amp external fuse required (not included)
23.4" L x 9.9" W x 2" H
$1099 US Dollars - MSRP
My New Build checklist:
(3) 18'' btl fully loaded d2
about 800, youd have to find a dealer though, they may be able to cut you a deal for less,
but there isnt any in stock at this time so youd have to find a used one
what do you mean that there isnt any in stock :huh: everyone is out of stock or something??
if you already have D2's you could run each one on a single amp or both on 1 but again its pretty pricey and how much is the t3k you were looking at
i believe it was like 700-800. so for the price of the saz-3000 i would be getting almost the same amount as a t4k for half the price almost.
You could start with one @ 0.5ohm for around 4,000watts total then add another later. 6,000watts is what they're rated but I believe in the actual strapped test they made closer to 7,000watts.
so the numbers are max and not rms?
  • Who's Online   1 Member, 0 Anonymous, 1211 Guests (See full list)
