Help with trunk box SSA XCON 15!
Fireitup
Will probably take my back seat out tomorrow and get some more measurements if i can bring it through the door and put it in through there we might be in business.
Other than being difficult to build you have to make sure the motor
doesn't hit the bottom of the box, also the port area of that 6" is kind
of low and there's now way around that, 3 4" flared ports will have a
hard time fitting there, still I would prefer for sure this to a sub
firing up.
firing up.
Everything out of the back of car and the height is.... 16! Headed to home depot to pick up the wood now to start building. Thanks for all the help Joe...Edit
Actually back in the car now to measure the width at the very top.. Just noticed that it might not be 33 by looking at the picture twice..
Fuck... Something doesn't want me to have the 15 in my trunk easy... 25 inches width at the top. Also small tabs at places make the height need to be 15.5 as well.. Back to the drawing board...
fuck it im gonna try it, will put the top on once its in the trunk..
Decided against this, i want to be able to pull the box out if i have to.
firing up.
I know you said not to Joe, and i value your opinion. But i gotta try it. Could you make the design 32hz, 4ft3 14 height, 32 width unknown depth, vertical slot port to P side and i know you don't want to hear this, sub UP. <3 Joe
As long as no one says I recommended it I will draw it, anyhow you wouldneed 5" of free airspace in front of the port for it to work, don't know if you have that to the side?
as long as it is vertical on the front side of the box i wiil. edit. i mean trunk side of box not cabin side.
