AQ HDC3 15" Box Help
oTurtlez
So the next upgrade is an HDC3 15" running on an AQ1200. I know the whole, 4.5^3, tuned to ~35Hz with 60^2" of port but I cant quite get it in the size constraints I'm putting on it. Main problem being port volume. I can get everything else perfect but not the port. I'm going for a vertical sub and port (IE, both on top) And I want to retain some trunk space (Hummer H3) and believe me, they have deceptively small trunks (42.5" wide x ~30 deep) Dimensions for the new box are here in Torres, and I know the port length is WAY too short but I don't know what to do. Help would much appreciated, thanks.
Sub is mounted on top bro ... 14.5 height is fine
DFAC
Beating Down The Block
2013 Kenworth T-660 Studio Sleeper-The daily and Money maker
I do what I want -push it till it pops!
Don't forget to add in displacement. I think its .23 or .25
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
you need WAY more port. like, almost three times as much.
i hope you plan on bracing the box.
you also need to put a number in for the # of common port walls. read the help file for more info on that.
You need more port, like 16 per at a tuning of 36hz like AQ recommends since the sub has a very very stiff spider
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Like I said, I know I need more port, which is why I came here for dimension recommendations. I'm not trying to be an ass but when everyone continues to post "You need more port", it's not helping me a huge amount :/
EDIT: New dimensions. I've got plenty port now, as well as some bracing. Tuning is a bit higher than I'd like as well is volume. Recommendations?
aim for 16sqin per cube. you're at 12.5 right now.
just make sure you have the # of common port walls correct (either 0, 1, 2, or 3) and that your port height and width will actually fit inside the box :D
  • Who's Online   1 Member, 0 Anonymous, 281 Guests (See full list)
