wiring single voice coil
EdgarG0721
I think you are limited to either 1ohm or 4 ohm, or higher.
You could run pairs in series like (8ohm+8ohm) : (8ohm+8ohm) : (8ohm+8ohm) : (8ohm + 8ohm). That would give you 4 16ohm pairs of drivers. Then wire those set in parallel and you would get 4 ohms.
You could wire all of it in parallel and get (8ohm~8ohm~8ohm~8ohm~8ohm~8ohm~8ohm~8ohm). That gives 1ohm
If you split it into two groups you could wire each set of 4 to 2ohms though.
  • Who's Online   1 Member, 0 Anonymous, 962 Guests (See full list)
