Question about Amp RCA'S
Afficionado
If you have a 4 channel amp for your component speakers and it is two sets of RCA inputs, do you need 2 sets of RCA'S, do they both have to be plugged in? Please explain this to me, what effects not having them would have, and really anything about it. To avoid any confusion, what i mean by two sets of RCA'S is this.
OO Front
OO Rear
If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
Do you have an eq you run your headunit into?
Does your HU have Multiple rcas out? 2sub 2channel 4channel?
What Amp do you have?
Generally yes.
Run it as a slave from your original amp. RCA from HU to amp, then RCA from amp to 4 channel amp.
I have a Pioneer AVH-p2400 headunit.
No eq.
1x T1500, will be adding a second soon.
1 P400.4
1 p450.4
Will soon be adding a p200.2.
if you have two sets of preouts and you want to keep front/rear fading capabilities, run two sets of rca's.
I will be having 3-4 amps for my component speakers. do i daisy chain all of the RCA's from amp to amp?
two sets allows you to use your EQ on your head unit after you add amps and stop using head unit power for mids/highs. not sure what you mean by daisy chain, but if you mean use RCA y-splitters, then yes.
well, some amps have outputs, which i assumed was so that you could hook another RCA from that amp to another amp, rather than having to run another one from the HU.
Both sets are inputs, so how would that work with an EQ?
some do, yes. I haven't seen many 4 channel amps with input and output, mostly mono block amps. did I saw EQ? I meant fade control
  • Who's Online   1 Member, 0 Anonymous, 1074 Guests (See full list)
