FosgateLife Posted February 5, 2013 Author Report Posted February 5, 2013 Looking through this thread it seems there's a whole lot of I can't and I won't...your asking us to help you but you seem unwilling to do anything to find it yourself. for your answer, you may just have to take the door apart and trace the wires man. I am willing to work with what i have. Thats the thing. The car is way too complicated for me to even touch forreal. You'd understand if i took pictures. 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Carbon Posted February 5, 2013 Report Posted February 5, 2013 The wiring looks fine. Is your crossover functional?
FosgateLife Posted February 5, 2013 Author Report Posted February 5, 2013 The wiring looks fine. Is your crossover functional? Im sure it is, its working only with the tweeter though. So im just running the mid range in the stock location with stock wirs. I know its dangerous...... But im not playing volume loud so im alright until i get it fixed...should i just get someone to run new door wires? 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
FosgateLife Posted February 5, 2013 Author Report Posted February 5, 2013 Maybe this will clear up some stuff What should i do? Ive tried doing everything i can think of and it wont work. 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
FosgateLife Posted February 5, 2013 Author Report Posted February 5, 2013 Ive just settled for using bass blocks so i don't damage the mid range. i don't wanna run new door speaker wires so this is my only other option. 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
bcbrassard Posted February 5, 2013 Report Posted February 5, 2013 wow dude, you need someone to help you since your unwilling to fix it right. your panels off, thats more than half the battle to getting the new wires in. Its not the cross over, the bi-amp switch comes turn off on those and you have to open them up to turn them on. Mine bi-amped so i know, i have the same speakers. Check the wires goiing into the xover carefully. good luck!
FosgateLife Posted February 6, 2013 Author Report Posted February 6, 2013 wow dude, you need someone to help you since your unwilling to fix it right. your panels off, thats more than half the battle to getting the new wires in. Its not the cross over, the bi-amp switch comes turn off on those and you have to open them up to turn them on. Mine bi-amped so i know, i have the same speakers. Check the wires goiing into the xover carefully. good luck! So how do do hook them up from there? Both inputs? Or just 1 input? Which eire? Tweeter or woofer???? 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
