GatiBeats Posted February 5, 2013 Report Posted February 5, 2013 I drive a 06 Pontiac Grand Prix which has a small (and awkward) trunk opening. Because of this, my box must be within 36w x 15d x approx. 17h. It also must me 1" mdf all around and 2 in the front. I went to a local audio shop and they told me a build for my Orion HCCA 15 would be nearly impossible and cost over $700 in labor alone. The back of the box needs to be at least an inch away from the rear of the sub since it is pole vented, and the magnet requires a support to hold it up, rather than putting all of the stress on what is mounted. I was shooting for around 3.5-4ft^3 at 33-35hz. Any ideas on box and port dimensions? 06 pontiac grand prix alpine ida x100 rf t2 comps rf t1500, t400-2 knu 0 big 3 xs d3400 oct 11 tentatively: 2 obsidian 18 v2's
Joe X Posted February 5, 2013 Report Posted February 5, 2013 Ok so this could be done: Enclosure Specifications:Fb = 35 HzVb = 3.5 ft^3External Height = 17.25 inExternal Width = 36 inExternal Depth = 15.25 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Front & Back (3 parts) = 36 x 17 1/4Left & Right Sides = 13 x 15 3/4Top & Bottom = 36 x 13Port Quantity and Dimensions:Number of Ports = 1Pipe Port Diameter = 6Pipe Port Length = 13 3/8 Threaded metallic bracing 1/2" as shown, the aero port needs about 6" clearance in front of it for proper operation, if that is not possible a bent aero port should be used firing forward.
GatiBeats Posted February 6, 2013 Author Report Posted February 6, 2013 Ok so this could be done: Enclosure Specifications: Fb = 35 Hz Vb = 3.5 ft^3 External Height = 17.25 in External Width = 36 in External Depth = 15.25 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 36 x 17 1/4 Left & Right Sides = 13 x 15 3/4 Top & Bottom = 36 x 13 Port Quantity and Dimensions: Number of Ports = 1 Pipe Port Diameter = 6 Pipe Port Length = 13 3/8 Threaded metallic bracing 1/2" as shown, the aero port needs about 6" clearance in front of it for proper operation, if that is not possible a bent aero port should be used firing forward. Is there a way I could use 2 4" ports rather than one 6"? and if so, how long would they have to be? Would a flared port be better? 06 pontiac grand prix alpine ida x100 rf t2 comps rf t1500, t400-2 knu 0 big 3 xs d3400 oct 11 tentatively: 2 obsidian 18 v2's
Joe X Posted February 6, 2013 Report Posted February 6, 2013 It's a bit less port area and you are somewhat low right now but if you want to do that then two ports 12 3/4" long will tune you the same, and yes you should use PSP flared ports. You will need 4" of free airspace in front of the ports for proper operation. EDTI: The flares of PSP ports are really big in diameter so one port would likely need to be low and it may get a clearance issue.
GatiBeats Posted February 6, 2013 Author Report Posted February 6, 2013 I was looking at using one of these port kits: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=268-352 It says the outside flare diameter is 7 1/4" so if I put them 1/2" apart and 3/8" from the top an bottom, theoretically it should work out. 06 pontiac grand prix alpine ida x100 rf t2 comps rf t1500, t400-2 knu 0 big 3 xs d3400 oct 11 tentatively: 2 obsidian 18 v2's
Joe X Posted February 6, 2013 Report Posted February 6, 2013 Right, there is enough space to install them but you should make sure that there is 4" clearance in front of each of the two ports.
GatiBeats Posted February 9, 2013 Author Report Posted February 9, 2013 Assuming I used the 6" port, would it change the tuning if I made the port external? 06 pontiac grand prix alpine ida x100 rf t2 comps rf t1500, t400-2 knu 0 big 3 xs d3400 oct 11 tentatively: 2 obsidian 18 v2's
Joe X Posted February 9, 2013 Report Posted February 9, 2013 Yes, you can run it partially external or entirely external, as your net volume grows the tuning would drop some but just adjusting the length of the port can tune it back to 35Hz.
GatiBeats Posted February 9, 2013 Author Report Posted February 9, 2013 So if the net volume grew I would need to make the port a little shorter? 06 pontiac grand prix alpine ida x100 rf t2 comps rf t1500, t400-2 knu 0 big 3 xs d3400 oct 11 tentatively: 2 obsidian 18 v2's
Joe X Posted February 9, 2013 Report Posted February 9, 2013 That's right, if you tell me how you plan to set it up I can tell you the new length.
