Rookie Help!
ballhard365
they use bolts mounted to the side of the box in order to parallel/series the coils. you can do 1 terminal per bolt, or wire all +'s to 1 bolt and all -'s to another bolt. however you want to do it. you probably can figure out what i mean by that.
I think he is asking how to fit the 8GA into the terminals on the actual sub itself.
Twist them as tight as you can, you may get lucky. On my SA's I just trimmed a little bit of wire from the edges, twisted and got it in.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
Okay, sorry very new.. How do you exactly paralel it with the bolts? and does it matter the bolt? I was told to use a wing nut on one end also
Thanks man! I wasnt sure if you could trim a little of the wire or not
  • Who's Online   0 Members, 0 Anonymous, 881 Guests (See full list)
