Extra battery question
I just bought a yellow top optima. And I want to add a battery to the back. My question is do I have to get the same battery for them to charge/work right?
(2) PSI p2 18's
Crescendo 2000
Audio Technix 0 gauge/ SHCA 0 gauge
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
You want something with the same technology, AGMs with AGMs, wet cell and AGM do not mix. Matching companies is good because they generally rest at different voltages or discharge differently which can weaken stronger batteries when a weaker one is in the system. You can connect the back battery to the front battery or alt, it will work fine either way, I don't thing you are worried about squeeZing a few extra watts out so I would just connect it to the front battery.
And no, wiring to the front battery vs the alt will not cause any major extra stress, the front battery's charge cable and the back battery's charge cable whether they are on the alt or one is to the front bat, then the alt, are in the same circuit therefore nothing really changes, they are all connected to the alt one way or another, one just has very slightly less resistance that is negligible in most cases
So if I bought a smaller xs battery it would work fine? Noobie question but to wire it up right you run the pos form front battery to the one in the back, and neg from frnt to neg to back? Right? Then run then run positive from back batt to amp and neg to amp?
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
Your batteries are only as good as the weakest link.
agm-agm only. Preferably all the same brand
Yellow tops are to high for me to buy another one lol
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
so if i keep my reg wet cell battery in the front and run the 0 gauge to the rear battery straight off of the alternator that should be good? i ordered a second battery as well so i will havde two rear dekkas and one front wet cell.
or would it be better to wire one dekka in the front as a main battery and then just keep the other dekka in the rear and wire them together?
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
