JimmyBaldin Posted February 10, 2013 Author Report Posted February 10, 2013 3 runs +, and i guess you to ground it on the main battery, Mechman have a sale on the XS-Power CCA wire for 119 the 50 ft. spool. yeah but what is the difference between grounding in the rear and grounding on the main battery??? better connection ?
JimmyBaldin Posted February 10, 2013 Author Report Posted February 10, 2013 You got a 1600 dollar amp... 1000 dollar subs ....1300 dollars in batteries an if I'm reading this right you wanna use just 4 runs of positive an grounding to the frame? never paid 1000$ for the sub lol. yeah and its much $$$ over here .. brokerage fees and taxes. shipping.. lol canada is the worst country for shipping something. yeah im asking if grounding to the frame is the same or grounding to the front battery is better.
purplesyrup Posted February 10, 2013 Report Posted February 10, 2013 I found that when I ran 3 more grounds off my battery I had a much higher current draw, I am curious too how grounding the amp all the way back to the battery would be beneficial, rather than it being grounded to the frame near the amp.
JimmyBaldin Posted February 10, 2013 Author Report Posted February 10, 2013 I found that when I ran 3 more grounds off my battery I had a much higher current draw, I am curious too how grounding the amp all the way back to the battery would be beneficial, rather than it being grounded to the frame near the amp. yeah thats what i want to know. if my voltage will be much solid with grounds to the front batt
Swordlordboy1234 Posted February 10, 2013 Report Posted February 10, 2013 In for results. I thought damore proved this grounding to the frame vs extra runs for under 10k watts. But maybe other people have more input. I'm gonna need this info on my next build if you know what I mean My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Nate Futuristic Posted February 10, 2013 Report Posted February 10, 2013 In for results. I thought damore proved this grounding to the frame vs extra runs for under 10k watts. But maybe other people have more input. I'm gonna need this info on my next build if you know what I mean I thought it was for 4k and under use frame? down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
JimmyBaldin Posted February 10, 2013 Author Report Posted February 10, 2013 In for results. I thought damore proved this grounding to the frame vs extra runs for under 10k watts. But maybe other people have more input. I'm gonna need this info on my next build if you know what I mean I thought it was for 4k and under use frame? and if i use ground from front to rear with rear ground would it be good you think?
Nate Futuristic Posted February 10, 2013 Report Posted February 10, 2013 In for results. I thought damore proved this grounding to the frame vs extra runs for under 10k watts. But maybe other people have more input. I'm gonna need this info on my next build if you know what I mean I thought it was for 4k and under use frame?and if i use ground from front to rear with rear ground would it be good you think? I do both ground and power runs I'm sure you could do frame grounds for a daily system.... If your chasing numbers do full runs down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
JimmyBaldin Posted February 10, 2013 Author Report Posted February 10, 2013 In for results. I thought damore proved this grounding to the frame vs extra runs for under 10k watts. But maybe other people have more input. I'm gonna need this info on my next build if you know what I mean I thought it was for 4k and under use frame?and if i use ground from front to rear with rear ground would it be good you think? I do both ground and power runs I'm sure you could do frame grounds for a daily system.... If your chasing numbers do full runs doing daily
