8ight Posted February 12, 2013 Report Posted February 12, 2013 One of your grounds must be poor. Check resistance with a multimeter. I'm gonna hate
evermaxx Posted February 12, 2013 Author Report Posted February 12, 2013 Crimped using knu wire. Sanded grounds good, all shinny. And I just added. Didn't replace stock. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
Carbon Posted February 12, 2013 Report Posted February 12, 2013 Crimped using knu wire. Sanded grounds good, all shinny. And I just added. Didn't replace stock. Not to be obvious but how did you crimp?
Carbon Posted February 12, 2013 Report Posted February 12, 2013 It could be an underlying problem that has nothing to do with the big 3. Looks like youve done everything right.
ccmotox99 Posted February 12, 2013 Report Posted February 12, 2013 that's really odd. Maybe you're alternator just a junker..? Lol i'm stumped. -playing with different setups
Carbon Posted February 12, 2013 Report Posted February 12, 2013 Thinking about it more... What does your voltage look like when your lights are dimming? Do you have any batteries in the trunk?
evermaxx Posted February 12, 2013 Author Report Posted February 12, 2013 Nah, just stock battery. It's over 14 volts now, but it just seems tgey dim more. Thought doing this would atleast reduce it. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
Carbon Posted February 12, 2013 Report Posted February 12, 2013 Nah, just stock battery. It's over 14 volts now, but it just seems tgey dim more. Thought doing this would atleast reduce it. Problem solved.
evermaxx Posted February 12, 2013 Author Report Posted February 12, 2013 So even if it's charging over 14 volts, the lights would dim more? Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
Carbon Posted February 12, 2013 Report Posted February 12, 2013 So even if it's charging over 14 volts, the lights would dim more? If all you have is a stock alternator and battery you have a good chance your voltage is dropping when the bass hits.
