evermaxx Posted February 12, 2013 Report Posted February 12, 2013 Well till I could order my battery I thought id get the big III done. After I did, it seems my lights dim more.. kinda confused. Negative battery to ground Engine to ground Alt to battery Now on my car 2003 jeep grand Cherokee, the stock alt wire goes to my fuse box. Shohld I have did alt to fuse? Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
DubNDodge Posted February 12, 2013 Report Posted February 12, 2013 Did you leave all your stock wires in place? The big 3 should be adding onto your original wiring. Not replacing. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Carbon Posted February 12, 2013 Report Posted February 12, 2013 Did you leave all your stock wires in place? The big 3 should be adding onto your original wiring. Not replacing. I replaced mine with no issues and 100% gains.
Cox Posted February 12, 2013 Report Posted February 12, 2013 Make sure your original wires are in place and I cannot stress enough to make sure you have proper grounds. Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Carbon Posted February 12, 2013 Report Posted February 12, 2013 Make sure your original wires are in place and I cannot stress enough to make sure you have proper grounds. Use a wire brush bit to remove all rust / paint from chassis before connecting! Why do you emphasize to leave the stock wires? From my pictures my stock wires do not look like they do any good at all compared to the 1/0.
Cox Posted February 12, 2013 Report Posted February 12, 2013 Make sure your original wires are in place and I cannot stress enough to make sure you have proper grounds. Use a wire brush bit to remove all rust / paint from chassis before connecting! Why do you emphasize to leave the stock wires? From my pictures my stock wires do not look like they do any good at all compared to the 1/0. Not really emphasizing to leave the stock wires, just more as a precautionary prevention of stupid crap happening in certain cars. Especially the power wire. Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
DubNDodge Posted February 12, 2013 Report Posted February 12, 2013 Just trying to troubleshoot why his lights are dimming more. The only reason I say add on is I know that in my car the stock Alt+ to Bat + branches off and goes somewhere else(I didn't bother to follow it) If I were to just disconnect that wire from the battery or the alt I can see that there would possibly be issues created. But yeah, if you are just replacing a ground wire, there shouldn't be an issue. OP, did you sand down all the locations of your grounds? Is your bat- to chasis ground and engine ground to chasis ground in the same location? How did you connect your ring terminals onto the wire? Edit: fixed grammer. I'm tired and my grammar is crap. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Carbon Posted February 12, 2013 Report Posted February 12, 2013 Just trying to troubleshoot why his lights are dimming more. The only reason I say add on is I know that in my car the stock Alt+ to Bat + branches off and goes somewhere else(I didn't bother to follow it) If I were to just disconnect that wire from the battery or the alt I can see that there would possibly be issues created. But yeah, if you are just replacing a ground wire, there shouldn't be an issue. OP, did you sand down all the locations of your grounds? Is your bat- to chasis ground and engine ground to chasis ground in the same location? How did you connect your ring terminals onto the wire? Edit: fixed grammer. I'm tired and grammar is crap. I have 2 cables on my alt, One is stock and goes to the wiring harness the other is 1/0 to batt. Your point is valid
ric006 Posted February 12, 2013 Report Posted February 12, 2013 sounds kinda like a crappy ground man
elflako17 Posted February 12, 2013 Report Posted February 12, 2013 men like @ric006 said i think you have a shitty ground some where in there.. make sure all grounds are in a solid.you should have 2 negatives ground well done plus the positive from the alt to the battery 2010 Mazda 3 *Rebuild Time* Subs - (2) AA Mayhems 12's Sub amp - (1) Populus Audio TPA 6500 Headunit - Pioneer App Radio 2 Batteries - XS Power (1) D3100 up front | 6 XP950 rear Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1 Alternator - Singer 260 Externally Regulated Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors) Mids & high Amp : (2) Populus Audio 100.4 Processor: Rockford 3sixty.3 The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
