where to find an ignition wire?
There is no black/white wire. They are both green
Edit- i googled ignition harness and realized that you may be right. I wasnt looking at the ignition harness it turns out. Sorry about that. Im gonna check this out again
well i added a wire coming off the black/white wire and tested it with a dmm. you were right Will, thank you very much! sorry about not knowing what an ignition harness was.
now i just need to weld up a mount for the relay and i can finally install my new battery.
If key turns on your stereo then relay will turn on also linking battery's an not isolate them
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i was kind of confused by this post until i got everything installed, and now i think i know what you are saying kind of, but i'm still confused. i have noticed now that when i have the key in the accessory position that the HU runs off the front battery and the amps run off the back one. i hadn't really thought about that before.. is there any way to remedy this besides running a power wire from the HU to the second battery and throwing a switch on it (basically putting everything on a switch and eliminating the need for a key)?
if not then adding another power wire and a switch should work right? i was actually thinking about doing that anyways so that i could run the stereo without having the keys in the ignition (then i can listen to music drunk at a party but not get a dui because my keys are in the ignition just for music ;) )
  • Who's Online   0 Members, 0 Anonymous, 1315 Guests (See full list)
