Subwoofer set up for under 1200
Antonio Moore
How big is that yellow top and how big is the alt currently on the car?
Are you okay with buying used or you only want new?
How much space do you have yo work with in the trunk?
It fits 2 15 in pretty large ported box. Not sure how much alt puts out im guessing about 110 though I don't mind buying a used alt. d35 batt
audioque hdc3's. but two of those will laugh at the t1000. even one will.
Current system
In 04 Buick lesabre
T2 6.5 comps
T1 6x9
T600-4
Yellow top optima
Not Looking to spend much.. no more than $1200
For my low end any suggestions on the best I can get for the budget?
I guess you 2 Sundown SA series sub, or SKAR VVX in the size you want, a Hifonic´s BRZ 1700, a batt and a H/O alt till 250 amp´s.
I have batt and I'd rather pay more than get a hifonics amp
I tryed to stay in your need´s and budget. 2 Sundown SA 12 are http://www.ebay.com/itm/TWO-SA-12D4-SUNDOWN-AUDIO-12-DVC-4-OHM-SA-PRO-LOUD-BASS-SUBWOOFERS-SUBS-PAIR-/120824910509?pt=Car_Subwoofers_Enclosures&hash=item1c21b9d2ad 400 $, the Hifonic´s amp is http://www.ebay.com/itm/Hifonics-BRZ1700-1D-1200-Watt-Class-D-Monoblock-Car-Amplifier-/350624247466?pt=Car_Amplifiers&hash=item51a2d56eaa 220, if you want something other i guess
you the SQ(before AQ) 1200 http://www.soundqubed.com/Q1-1200D-Amplifier_p_30.html. Now we come to the problem that you give arround 2000 watt = 200
amp extrastrain to the electrical system of your car. If you want you can put a big/ger XS-batt in the trunk and you have them all vew day´s on the charger, + maby you need a special AGM batt charger. Or you do it right and upgrade your alt up to a H/O alt 200-250 amps, if you have luck you find a offer whith spec´s something near or with higher output. Than you need some wire, boxmaterial´s and it would be nice to have a vew squarefoot´s of dampener on the right places.
I don´t think that the SQ amp isn´t so much better amp than the BRZ line from Hifonics. The advantages of the Hifonics, is that you can compensate a vew watt´´s who
you loose in imprise and it´s a little bit cheaper than the SQ, the maby negativ is the more strain to the electrical system.
Possiblity of saving is that you can snatch up some of the item´s used or secondhand bnib for lower prices.
PS dont forget to do the Big 3 http://www.stevemeadedesigns.com/board/topic/13280-how-to-do-the-big-3-tutorial/
"in the abundance of water, the fool is thirsty" Bob Marley
Current system
In 04 Buick lesabre
T2 6.5 comps
T1 6x9
T600-4
Yellow top optima
Big 3 hmm sounds like a tough job my car battery is under the backseat may be tough runnin that to alternator
You could look into American Bass, the XFL line is pretty good and reasonably priced.
i x2 this as well.
well you're gonna have to do it regardless.
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
