From the sounds of it looks like your electrical system needs to be upgraded. The basic Big3. Plus your gonna want to go 1/0 if you plan on running an Audiobahn amp (those amps are whores). An alt upgrade and a second battery is going to be your best to stop the lights dimming. Not sure if the Kinetik 600 will fit up front if so put that there and run a second battery to the back a 2400 if possible. Your running 15's and unless they are a flea market brand that is not a small system. A small system is a single 10 or 12 sealed off of 100 watts. That should help your lights from dimming and if your lucky probably get a little lower and a little louder.
the hc 600 is the size of a motor cycle battery but ill probably just do the big 3 and when i get some extra cash ill just replace the batt. up front.
thanks for the advice everyone it helps.
