Bus Bar/Electrical ????'s
I am needing a couple ?'s answered if someone will help here. 1st need to know what material is best to use for best results for bus bar between to batteries in trunk. I am adding a 2nd battery and also if someone can tell me if I have 2 runs of 0 gauge to rear battery do they both need fuse blocks in between both runs. Currently I have 2 runs of 0 gauge going to rear stinger battery and only one is fused with an 80 amp then from rear battery to both amps is a fused distribution block with 2 200 anl fuses. I have a bre2000.1d and a Diamond D6 700.4. My lights are still dimming after 1950 cranking amps from stock battery and spv70. I have 200 amp alt and big 3 done also so this is why I am adding 3rd battery. Thanks
200amp HO
Big 3
Diamond Audio S500s (front)
Diamond Audio M65.1a (rear)
Kenwood KIV-BT901
Kicker, Stinger, Knu 0 gauge, 4 gauge
Kinetik HC2000b x 2
Hifonics BE2100.1
Memphis MR4.480
SQ HDC312's x 2 36hz
Best metal for buss bars would be silver, but that's not practical. Copper would be the next best followed by aluminium. All your + runs between front and back batteries should look like this, front batt.-----fuse-----------------fuse-----rear batt. If your running full spec copper 1/0 gauge use 250 amp fuses for your runs between batteries
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
Aluminum has worked awesome for me, i´ll be updating the SPL gains topic soon with a test i did, wires directly to terminals vs aluminum 1/4" , works awesome, should work even better with thicker bars ;)
  • Who's Online   1 Member, 0 Anonymous, 2694 Guests (See full list)
