network help?
Hey guys and gals. having a little problem with my network:
. How do I have wireless and wired pcs on a network and have them see each other? example: my pc is connected through ethernet cable, my ps3 is connected wirelessly. How do I get both of them to see each other on the network? all of my ethernet conected pcs dont see any wireless connected devices at all.
I'm using verizon fios with an actiontec MI-424-WR Rev E. router.
let me know if you need any other info.
I just want my wireless ps3 to stream music from my pc like my xbox360 does.
1996 Vw Jetta
Crunch 1500watt
1- Kicker 15" L7 @ 1ohm in a 4cu. ft. Ported Enclosure Tuned to 32Hz.
4- 6.5" Menace Door Speakers &
2- Menace super tweeters in the dash
139.11db @ 40hz (6/2010..old amp setup)
firewall blocking ps3? WMP not setup to stream to ps3?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
it just seems like the wireless is seeing anything connected with an ethernet cable and vice versa.
my ps3 WILL see my computer and work fine if I plug the ethernet cable from the xbox into it.
I have 2pc's (ethernet), an xbox360 (ethernet), a laptop (wifi), and my ps3 (wifi) on my network. I have sharing setup on my pc which the other pc and xbox360 can see, but the laptop and ps3 dont show up on the pc's or the xbox.
1996 Vw Jetta
Crunch 1500watt
