Recommended ohm load?
masterbusa2
I have 2 Planet Audio 2400.2's that's Gunna power 2 15" crossfire xs v.2's so I assume I wire one amp to each sub, then from amp to amp with RCA, then power wires going from amp's seperate 1/0gauge going to the second XS power 3400D from that batt with bus's bar from Batt2 to batt1 then from there up to front brand new oem batt with 1/0 gauge one for hot and one for ground, then from there to alt, 300amp irragi, also on each batt extra grounding 1/0 gauge less than 2ft, should I wire each sub to .5 or 1 or 2? Going for hairmovement
Sorry in essence with the correct voltage can I run my dual 2 ohm subs using my 2 2400.1 amps Do I wire to .5, 1, or 2 ohms if I am wanting to go for power, also is the planet audio amp capable of .5 even though it's an 1 ohm stable amp
  • Who's Online   0 Members, 0 Anonymous, 1042 Guests (See full list)
