afrakes Posted February 28, 2013 Report Posted February 28, 2013 What COULD happen if I ran 2500 watts of true power on my stock electrical? Besides killing my stock battery could anything else really get damaged? Assuming my power and ground are large enough to carry the current without catching fire. Vehicle: 2014 GMC Sierra 2500HD WT Head Unit: Pioneer DEH- Mids/Highs: Focal Integration ISC 165’s (front) Subs/Amps: TBD
will77530 Posted February 28, 2013 Report Posted February 28, 2013 can fry alt can blow amp can blow sub can have a really bad day
Guest Posted February 28, 2013 Report Posted February 28, 2013 can fry alt can blow amp can blow sub can have a really bad day basically this.
ccmotox99 Posted February 28, 2013 Report Posted February 28, 2013 I had an audioque 2200d on my stock electrical for about a month on 2 DD 3510s, never had any issues other then voltage drop and headlight dimming. I would NOT recommend doing it though unless you have a lot of money to replace your equipment if damaged. -playing with different setups
Antonio Moore Posted February 28, 2013 Report Posted February 28, 2013 can fry alt can blow amp can blow sub can have a really bad day I think it would just ruin amp and battery not blow subs and amp but I would play it safe with more power
will77530 Posted February 28, 2013 Report Posted February 28, 2013 can fry alt can blow amp can blow sub can have a really bad day I think it would just ruin amp and battery not blow subs and amp but I would play it safe with more power voltage dropping causes clipping which damages amps and subs your wrong sry
Guest Posted February 28, 2013 Report Posted February 28, 2013 can fry alt can blow amp can blow sub can have a really bad day I think it would just ruin amp and battery not blow subs and amp but I would play it safe with more power lol no. like will said, voltage drop makes amps clip earlier. so instead of being clip free at volume 50 at 14v, you'll start to clip at lets say volume 40 at 12v. and you're riding at volume 50 the whole time, you're just clipping the day away.
Antonio Moore Posted February 28, 2013 Report Posted February 28, 2013 can fry alt can blow amp can blow sub can have a really bad dayI think it would just ruin amp and battery not blow subs and amp but I would play it safe with more powerlol no. like will said, voltage drop makes amps clip earlier. so instead of being clip free at volume 50 at 14v, you'll start to clip at lets say volume 40 at 12v. and you're riding at volume 50 the whole time, you're just clipping the day away. Ohhh food for thought thanks. What amp are u using btw
Guest Posted February 28, 2013 Report Posted February 28, 2013 can fry alt can blow amp can blow sub can have a really bad dayI think it would just ruin amp and battery not blow subs and amp but I would play it safe with more powerlol no. like will said, voltage drop makes amps clip earlier. so instead of being clip free at volume 50 at 14v, you'll start to clip at lets say volume 40 at 12v. and you're riding at volume 50 the whole time, you're just clipping the day away. Ohhh food for thought thanks. What amp are u using btw none. my aq1200 is sitting in the closet. had it ran on a 70 amp alt. wouldn't have ran anything bigger than that without alt upgrades.
will77530 Posted February 28, 2013 Report Posted February 28, 2013 piece of shit soundstream 1700 dtr
