2011 Jeep + 8 Sundown 8's + 450.1 (Subs in and movin page 4)
You got a white ranger? Diamond plate box in back?
Cant wait to see this complete. Those v2's are beast. About to get 12 plus an NS-1 for the Ranger.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
Well gettin more goodies as we go.. Still plenty cold outside to do a damn thing.
Some buss bars I cut up at work.
Some goods from Knu Konceptz and Kinetik.
One more battery and some nice weather.
Sub Amp: AB 450.1
XS D3100
Come on 150!
  • 1 month later...
Okay.. So it's been pretty decent outside. Got a couple small things done and the last of the materials are on order.
I bought a set of Massive components.
Took a quick video of the Infinity coaxials that I used to have up front for some fun.
After some thought, I figured the best place to mount the tweeters were on the little plastic trim pieces behind the mirror. So I marked the holes and went at it.
Mounted them up and wa-lah.
I'm not the biggest fan of those slide connectors so I just soldered leads on both the woofer and tweeter
Extended the original wiring so that they'd reach the crossovers and pinched 'em together with some caps.
Mounted the woofer and drilled a small hole in the bottom corner of the little 'cubby' in the door, then pulled the wires through.
Wired up the crossover
Buttoned up the crossover and popped the cover back on.
Sub Amp: AB 450.1
XS D3100
Come on 150!
Movin' the Infinities to the back and just keeping them on head unit power.
Time to ditch the rear stockers finally..
Cut a bit of the plastic behind the stock speaker so the new one fits.
Cut the factory plug off and strip the wires.
Wire up the input..
And I have finally ditched all stock stereo equiptment.
Sub Amp: AB 450.1
XS D3100
Come on 150!
And the reason I put the audio aside for so long. :(
22's mang!
It's getting dropped 2" and the exterior shizz is done.
Sub Amp: AB 450.1
XS D3100
Come on 150!
should look pretty good once dropped.
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
Coming along nice, the subs are beasts. Digging the front stage as well
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
