David Stockdale Posted March 4, 2013 Report Posted March 4, 2013 Guys, I picked up a used 3Sixty.2 and need that install CD. Rockford has not been very helpful. Steve had one posted a couple years ago but the link is dead. Can someone help? Thanks Like Nothing Else..... 2012 Ford F-150 FX4Factory HeadunitGoogle Nexus 7Rockford Fosgate P2D4-12 SubRockford Fosgate P500.1 (Sub Amp)Rockford Fosgate P165S Front ComponentsRockford Fosgate P165 Rear DoorsRockford Fosgate P400.4 (Doors Amp) Dynamat All Doors
Kyblack76 Posted March 4, 2013 Report Posted March 4, 2013 Rockford Fosgate not helpful? your the first person ive EVER seen write that. lol.... Here is track 1 and 2. The most important for set up....... This is just easily found on the RF site. If you need thier number, and want to talk to them, its 1800-669-9899 and ask for Forest or Amy. I LOVE RF support. Never had any better.... ever... Click the link, and on PAGE 2, there will be the 2 tracks to down load and use for the set up of the .2 http://www.rockfordfosgate.com/support/rftech.aspx?kbsrc=http://rftech.custhelp.com/cgi-bin/rftech.cfg/php/enduser/std_alp.php?p_cv=1.65&p_pv=&p_prods=0&p_cats=65&p_hidden_prods=&p_page=1&p_allorg=&advsearchmode=1&p_search_text=&p_new_search=1&prod_lvl1=0&cat_lvl1=65&cat_lvl2=0&p_search_type=answers.search_nl#knowledge Best of luck.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted March 4, 2013 Report Posted March 4, 2013 It will look like this... You want the LEVEL SET UP, and PINK NOISE 3Sixty.1 & 3Sixty.2 - software downloadsAnswer ID 704 | Published 03/27/2006 02:20 PM | Updated 05/01/2012 04:52 PMWhere can I download the software to setup my 3Sixty? This page contains software allowing you to setup and configure your 3Sixty Signal Processor. Several platforms are available so choose the one that best fits your configuration. CD-ROM Setup Files If you have problems with your source unit recognizing the supplied 3Sixty setup disc as a CD-ROM (it shows PC files instead of playing audio tracks) you can download the original source files here. These tracks could be downloaded to any device and used in leu of a CD player. Track # Description Duration Download Track #1 Level Setup 5 Min Track #2 Pink Noise 20 Min Windows Mobile Software The software below controls the 3Sixty.1 and 3Sixty.2 with your Windows Mobile device. There are two versions, touchscreen and non touchscreen. There are several resolutions available for the touchscreen version, QVGA, QVGA square and VGA. Currently this support covers the majority of the devices available. In order to use the 3Sixty Windows Mobile software, you must meet the following requirements: • .NET Compact Framework 2.0 or newer • Display Resolution of 320x240 (QVGA) or 640x480 (VGA) • Microsoft Bluetooth StackModel Version OS Type Download 3Sixty.1 1.3.1 Windows Mobile VGA 480 x 640 3Sixty.1 1.3.1 Windows Mobile QVGA 240 x 240 3Sixty.1 1.3.1 Windows Mobile QVGA 240 x 320 (portrait) 320 x 240 (landscape) 3Sixty.1 1.3.1 Windows Mobile QVGA Smartphone (non-touchscreen) 240 x 320 (portrait) 320 x 240 (landscape) 3Sixty.2 1.3.1 Windows Mobile VGA 480 x 640 3Sixty.2 1.3.1 Windows Mobile QVGA 240 x 240 3Sixty.2 1.3.1 Windows Mobile QVGA 240 x 320 (portrait) 320 x 240 (landscape) 3Sixty.2 1.3.1 Windows Mobile QVGA Smartphone (non-touchscreen) 240 x 320 (portrait) 320 x 240 (landscape) SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
David Stockdale Posted March 5, 2013 Author Report Posted March 5, 2013 Thanks for the reply. I got both of those files already. Just wasn't sure if I needed anything else. Now just need to 3Sixty to get here. Like Nothing Else..... 2012 Ford F-150 FX4Factory HeadunitGoogle Nexus 7Rockford Fosgate P2D4-12 SubRockford Fosgate P500.1 (Sub Amp)Rockford Fosgate P165S Front ComponentsRockford Fosgate P165 Rear DoorsRockford Fosgate P400.4 (Doors Amp) Dynamat All Doors
