one ? what do you use to shrink heat shrink. ive been wanting to do that in my builds
I don't really know i got it from work at my dealership its what they use it has this nice goo inside for some water tight shit
Now time for the tweeters i had them originally on my front doors but i decided to put them in the a pillars to make it look like the factory Bose came out decent since i made the wholes my self
customtweeterpodforburban_zpsced07c4f.jp
All in
Here on the rear doors I'm guessing since its kind of curved the little Rockford brushed aluminum surround things wouldn't stay on
Don't have any pics of the front doors going in but it all went smoothly can't say the same about the rear though
This was the first issue
Got it fixed but phone was acting gay and a couple of pics came out like half gray and retarded so that's a missing picture of the fix
Idk if you guys can tell but the guide for rear glass hits the magnet of the mid on both doors
So now comes the power wire
Ran the wire through the big grommet of course haha
So this is what i got
0awgmonstercable400serieswmagneticflux_z
Its soldering 1/0 time
Or so i thought haha sucked so bad at it smh so i got something else "THE HELP" haha
And got me this crimper
And this is what it does
Got it hooked up did forget to take the pic for the fuse holder got a 150 amp anl fuse
Amp rack got it all cut up and mocking up where it'll all go
Drilled out all the wholes needed
Got the crossovers wired and passed all the wires through the holes
Mounted a relay to turn amps on
Here is the hidden mess
Amp rack done
Had it playing for a while and noticed a weird sound coming from the woofers i was like wtf turns out one of the woofers surround was coming loose it was on several spots
Solution
And the easiest way to get the goop really in there with no mess was this
So its now all set and done wire them to .5ohms figured with a bit of box rise should be fine i always bumping for.about a good hr almost full tilt every day and the amp doesn't mind it at all never gets hot and keep good voltage too get a small drop buy I'm guessing that's the efficiency i get from going .5ohms haha
Here they both are in their 1.5 cube box tuned at 32hz
So i was having a Lil voltage drop and finally decided to do the big 3 yesterday so here are some pics of that
I got me some new and different ring terminals which didn't fit in quite as easy as the other ones all thanks to this
So i had to do this
Got them all crimped and heat shrunk
Factory 8 gauge chassis ground
Factory 4 gauge engine ground well i think its 4 gauge
Swaped with 1/0
Using that heat wrap thing
New chassis 1/0 ground as well in factory locations
Going up and tied
Had a problem fitting a couple of this on that short screw on the positive side i prolly fucked up a thread or 2 but i wanted it done last night so
Had a busted car and used a terminal from it
Grinded down to clean it a bit
All raned
One more thing this wired has no flex what so ever was tough
Actual Update Got My New Amp Today Hopefully i Even Get In The Nominees To Get That High Output Alternator For This
This is What It Came In
Closes Thing I Had To Me To Open It
Lots Of Bubble Wrap
Finally The T2500Bdcp Of Course Used Got It Here On The Forum
Won't Be Going In For A While Since I Threw Myself On The S.O.T.M
not even close to being complete. Can not enter SOTM
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 1232 Guests (See full list)
