ImaNoob Posted March 9, 2013 Report Posted March 9, 2013 So i just installed my new componets and there is some feedback through them. With the volume down its only faint but i can here it, when i turn it up i cant tell if its there or not and doesnt get louder when i rev the engine... The Amp is Us amps 4 channel, rockford componets T1675-s .. My grounds are solid. I was thinking the Amp or RCAs but not really sure. Also there is one spot where the RCAs pass over the power wire but the power wire is under the carpet. I have no feedback through my sub and RCAs take the same path as highs amp.... 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
ImaNoob Posted March 13, 2013 Author Report Posted March 13, 2013 Anybody got some input on this ? I would like to get this taken care of..or is this normal ? 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
shogen Posted March 13, 2013 Report Posted March 13, 2013 make sure RCAs are secure..... also be careful with "hot swapping" RCAs ... check to see if adding a ground to the RCAs helps Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
ImaNoob Posted March 13, 2013 Author Report Posted March 13, 2013 I have never Hot Swapped RCAs, Or let them touch even with power off..Do i ground them at the Amp or at HU...Guessing HU ? Thanks for helping... 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
ImaNoob Posted March 13, 2013 Author Report Posted March 13, 2013 like this ? http://www.stevemeadedesigns.com/board/topic/160069-rca-outputs-grounding/?hl=%2Bgrounding+%2Brcas#entry2305981 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
shogen Posted March 13, 2013 Report Posted March 13, 2013 like this ? http://www.stevemeadedesigns.com/board/topic/160069-rca-outputs-grounding/?hl=%2Bgrounding+%2Brcas#entry2305981 yes you can try that Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
