Justscrap Posted March 11, 2013 Report Posted March 11, 2013 Wassup fellas? I was wondering if anyone could help me out with a box design for a single aq sdc 12"? It will be powered by a JL audio 500/1. Measurements I have for space is 14" H,13" D,32" W......any suggestions and hope is much appreciated...thx fellas! if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
Justscrap Posted March 11, 2013 Author Report Posted March 11, 2013 Also would 2 be better if I had more space or will the one 12 be fine on the JL 500/1,and I don't use my gain for a vol. knob either... if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
Justscrap Posted March 13, 2013 Author Report Posted March 13, 2013 Any suggestions? if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
Joe X Posted March 13, 2013 Report Posted March 13, 2013 Don't have the space for one on those dimensions.
Justscrap Posted March 18, 2013 Author Report Posted March 18, 2013 I could go more with depth let me know.... if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
Joe X Posted March 18, 2013 Report Posted March 18, 2013 It could be done like this: Enclosure Specifications:Fb = 35 HzVb = 2.4 ft^3External Height = 14.25 inExternal Width = 32 inExternal Depth = 16 inPort Width = 2 5/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:Front & Back = 32 x 14 1/4Left & Right Sides =Side 1 = 12 3/4 x 14 1/2Side 2 = 13 1/2 x 14 1/2Top = 28 5/8 x 14 1/2Bottom = 32 x 14 1/2L Port Internal Assembly Parts:Top to Bottom = 10 1/8 x 14 1/2Extension = 14 3/4 x 14 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 2 5/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
Justscrap Posted March 21, 2013 Author Report Posted March 21, 2013 Pm me joe x... if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
Joe X Posted March 22, 2013 Report Posted March 22, 2013 If you want the above changed just let me know what/how and will gladly do.
Justscrap Posted April 1, 2013 Author Report Posted April 1, 2013 I don't get the measurements for the side pieces, 12 3/4" and 13 1/2"? Let me know...thx! if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
Justscrap Posted April 1, 2013 Author Report Posted April 1, 2013 Also how much bigger would the box be if I were to add a second sub? Let me knw....thx joe x! if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned. If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick. It just does not make sense at all.
