cheebs Posted March 12, 2013 Report Posted March 12, 2013 i want to get a compressor to paint sub boxes and speaker pods. i have a good idea on what gun to get. the eastwood concours. i was wondering what would be the smallest size compressor as far as tank size i should get.
notbagd Posted March 13, 2013 Report Posted March 13, 2013 It would be helpful to know the SCFM needed for the gun you are buying first. Most compressors are rated for SCFM @ 90 PSI. Most HVLP guns need around 10 SCFM and you could get by with a 30+ gallon size compressor with small jobs. If you are going to be using it on a lot of small to medium jobs and you don't want to wait on the compressor to "catch up" and provide a consistent pressure and flow then I would go with a 60 -80 gallon size compressor. If you go with the bigger size compressor though most of them are 220V. Just my .02
Carbon Posted March 13, 2013 Report Posted March 13, 2013 Before I bought a nice tank, I had a small 10gal compressor from home depot. I was always smoking and waiting for it to catch back up. Go with a good size the first time around. Now my 10 gal is used exclusively for my nail gun.
cheebs Posted March 13, 2013 Author Report Posted March 13, 2013 It would be helpful to know the SCFM needed for the gun you are buying first. Most compressors are rated for SCFM @ 90 PSI. Most HVLP guns need around 10 SCFM and you could get by with a 30+ gallon size compressor with small jobs. If you are going to be using it on a lot of small to medium jobs and you don't want to wait on the compressor to "catch up" and provide a consistent pressure and flow then I would go with a 60 -80 gallon size compressor. If you go with the bigger size compressor though most of them are 220V. Just my .02 the eastwood concours gun of uses 4cfm @ 29 psi. i don't want to spend 400 or 500$ for a compressor i will only be using twice a year.
Airborne Posted March 13, 2013 Report Posted March 13, 2013 4 cfm is not enough. And NO ONE runs their compressor at 80psi when painting. 40 PSI is more like it...
Berto Posted March 13, 2013 Report Posted March 13, 2013 Get a HVLP Turbine. Those are pretty much made for painting. TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
cheebs Posted March 13, 2013 Author Report Posted March 13, 2013 4 cfm is not enough. And NO ONE runs their compressor at 80psi when painting. 40 PSI is more like it... im confused? how is 4cfm not enough? the gun uses 4 crm @ 29 psi. this i know. i didn't say anything about 80 psi. i understand a lil on how it should work. i just needed a feel on what size compressor should i be looking @.
notbagd Posted March 13, 2013 Report Posted March 13, 2013 25-30 gallon will be sufficient for what you are planning to use it for with that gun. Most compressors that size are still 110V so you can use any wall plug in your house. The gun usually has a regulator right before it enters the gun where you can knock the pressure down. My particular gun uses 25-30 psi depending on base coat or clear coat with a 1.4mm tip.
