Should i have my subline on 0 for tunning HU, i seen another post "trying to Google search" ( Not Here) saying to set to max for Max HU voltage to amps...But skimming through the PDF says nothing about subline..< If it does sorry ..Im getting my DD-! tomorrow so i figured i'd ask now...thanks
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
As long as it doesn't clip you'll be good the dd-1 will match the preout voltage to the amp gain
Example my kenwood kvt 516 volume clips at 33 of 35 sub level clips at 6 of 10 even if I was at volume 25 anything hire on the bass level would show clipping
So when I set it up I did 30 volume and 0 bass level
I wouldve gotten the same results if I would've used the max volumes
Cause it still matched the RCA preout voltage to the amp gain
