new box build not loud?!?
sbg
yep but the wires are crazy tight i had to pull them in the box with pliers
Did you just drill 2 holes and pass the wire through on the box ?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
External Height = 15.5 in
External Width = 33 in
External Depth = 16 in
peak seems high for that truck...you may have them wired out of phase or your box could just suck dimensions could help
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Port Width = 2 7/8 in
port?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
i have moved the box around and does not help, i can go out a trey to take a pick but its dark lol give me a sec...
Your port might be too close to the back hatch and could cause loading issues. also, can you post a pic of your amp settings?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
port?
Port seems kind of small IMO. Idk for sure though, box designs are not my forte.
*Rebuid in progress*
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 2.5 ft^3
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 33 x 16
Left & Right Sides = 14 1/2 x 13 1/4
2x Front = 15 1/16 x 13 1/4
Back = 33 x 13 1/4
Shared Port Internal Assembly Parts:
2 x Front to Back = 13 1/16 x 13 1/4
2 x Extension = 10 1/16 x 13 1/4
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 1301 Guests (See full list)
