new box build not loud?!?
sbg
did u see vid? page 2 post 5 take a look
think of it this way,
how well will a 6000 horsepower top fuel dragster run with 87 octane fuel
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
and imo moveing alot! i mean they got much more but still! they have 23mm xmax from what i have found online
they looked like they where moving in that video, must be outa phase.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
check the vid they move alot!
that would be a huge reason why they wont be loud,
if you only have 600w RMS, on 2 1500w RMS subs, thats the problem man, those subs will have such a stiff suspension, 300w per woofer is not enough to hardy move them, and you have high odds of damaging them from being WAY underpowered
Many 1000w to 1500 w RMS subs on the market will barely perform until they have that 1000 to 1500 watts of power
I saw them moving, but your not getting any SPL,
they are for sure underpowered, but also, could be out of phase or maybe one of them has a wire unplugged,
if a wire unplugged then you have one sub with power, another like a passive radiator, that combo, would make there be little output also,
cause if only one is getting power, then its trying to use the airspace for a box for 2 10"s with a port designed forf 2 10"s
EDIT: and if thats the case, (only one sub hooked up proper) that would be why the sub is moving so much because your nearly free airing because the box is so big
just another possibility
all good possibility's. as soon as i sell my other setup (cheap build 6-12s) i am going to look in to a SAZ3500 and some batterys and alt.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
its my day off today so as soon as the sun gets up so will i! and get in that box and see if i have problems in it.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
thanks for input on my problem from all who helped will update later today.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Oh ya, i know the wires barely fit through, but seal those holes anyways!
And underpowering doesn't damage your sub, dont trip lol
in a million, trillion, kabillion years,i would never play that song in my ride. I don't care if its clipped or not LOL. I feel like my nads got clipped after playing this for 15 seconds just to see what it was LOL.
No thanks bro. Not into it.
Under powering wont damage the sub if played responsibly, but if you try to over do it you will have problems
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
