Skater229 Posted March 14, 2013 Report Share Posted March 14, 2013 A few weeks ago I had a box built (Joe X design) for a pair of Sundown Audio E12-D2's... It works great other than the drivers are too small for the amp I have... In the process of the box being built and parts getting here I had upgraded the amp from a SQ1200 to a SQ2200... So to make a long story short the drivers can not handle the new found power... I am looking to build a new box but kinda torn on the sizes... The box I have now is nice sized but not sure if it can handle the drivers that I want to get... So I am looking for a design for the PSI 12's (if different from box I have now) and the PSI 15's both subs will be the platform 2 series @ DVC 1ohm... The max size of the box is 38w x 23d x 23d and would be made with 3/4 ply The current box works really well but as i said earlier got more power than planned and need to change the drivers out. Thanks for the help... T/S Parameters for standard Platform 2 12":Revc = 3.4 ohmsFms = 29.3 HzQes = 0.52Qms = 5.3Qts = 0.48Sd = 490cm^2Vas = 54.1 LBL = 15.5Mms = 198.3 gSensitivity = 85.8 dB @1W/1mSensitivity = 89.4 dB @2.83Vrms/1mXmax = 56mm totalUsable excursion = 3" total Product Dimensions:Overall diameter - 12.5" w/ gasketCutout Diameter - 11.125"Mounting Depth - 6.5"Displacement in enclosure - .16 ft^3Weight - 37 lbs T/S Parameters for standard Platform 2 15":Revc = 3.4 ohmsFms = 25.8 HzQes = 0.62Qms = 2.97Qts = 0.51Sd = 823cm^2Vas = 120.3 LBL = 15.5Mms = 290.3 gSensitivity = 88.86 dB @1W/1mSensitivity = 90.4626 dB @2.83Vrms/1mXmax = 56mm totalUsable Excursion = 3" total Product Dimensions:Overall diameter - 15.5" w/ gasketCutout Diameter - 14.125"Mounting Depth - 8"Displacement in enclosure - .16 ft^3Weight - 38 lbs Thanks... 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build Link to comment Share on other sites More sharing options...
Skater229 Posted March 15, 2013 Author Report Share Posted March 15, 2013 Joe X can ya help? 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build Link to comment Share on other sites More sharing options...
mr505 Posted March 15, 2013 Report Share Posted March 15, 2013 You should just pm him staight up brother Link to comment Share on other sites More sharing options...
