larrys95civic Posted March 17, 2013 Report Share Posted March 17, 2013 Ok, and Avery is correct about the ground, you want your ground to be as big as your power and the thin sheet metal it's grounded to isn't good. Also a tip for when you get your extra batteries I'd run 2 runs of 0 gauge power and 2 of ground from the front batt to the rear. Then you should probably do your big 3 soon. But back to the amp, any way you can take a video or pics of how everything is set up makes it a million times easier to trouble shoot. Team Superior SPL Former Installer at Driven Sound & Security http://www.drivenss.com All kinds of forsale threads http://www.stevemeadedesigns.com/board/topic/164247-amps-subs-and-misc/#entry2383262 http://www.stevemeadedesigns.com/board/topic/164430-polk-audio-sda6000-sound-bar/#entry2386634 http://www.stevemeadedesigns.com/board/topic/164279-3-michael-kors-watches/#entry2383983 http://www.stevemeadedesigns.com/board/topic/164549-more-items-from-storage/ http://www.stevemeadedesigns.com/board/topic/166967-dd-9518s-amps-kenwood-custom-explorer-dash/ If someone is feeling generous I'd love an original sig LOL Link to comment Share on other sites More sharing options...
Noel989 Posted March 17, 2013 Report Share Posted March 17, 2013 What's your settings on the amp and the headunit? Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
fox_racin4 Posted March 17, 2013 Report Share Posted March 17, 2013 clipping. your voltage is dropping when hte amp needs power, causing clipping, which i think would make the needle go into the red to show cliping 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
Noel989 Posted March 17, 2013 Report Share Posted March 17, 2013 clipping. your voltage is dropping when hte amp needs power, causing clipping, which i think would make the needle go into the red to show cliping Is not a clipping indicator Steve has said it and so has alot of other people on here Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
Avery Howell Posted March 17, 2013 Report Share Posted March 17, 2013 clipping. your voltage is dropping when hte amp needs power, causing clipping, which i think would make the needle go into the red to show cliping Is not a clipping indicator Steve has said it and so has alot of other people on here Yeah Steve said it is purely an output indicator and red just means max output. 2012 Jeep Wrangler 3.6 W/ 6 Speed Build Log 2011 Ford F-150 SVT Raptor 6.2 Build Log YouTube Link to comment Share on other sites More sharing options...
fox_racin4 Posted March 17, 2013 Report Share Posted March 17, 2013 clipping. your voltage is dropping when hte amp needs power, causing clipping, which i think would make the needle go into the red to show cliping Is not a clipping indicator Steve has said it and so has alot of other people on here clipping. your voltage is dropping when hte amp needs power, causing clipping, which i think would make the needle go into the red to show cliping Is not a clipping indicator Steve has said it and so has alot of other people on here Yeah Steve said it is purely an output indicator and red just means max output. meh. i dont follow RF amps so. i just know all the other amps that have a red flashy light its usually a clipping light so.. 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
11Staffordr Posted March 17, 2013 Author Report Share Posted March 17, 2013 Where's the easiest wat to get to the frame in the rear of the car? Link to comment Share on other sites More sharing options...
Trey_Dog650 Posted March 17, 2013 Report Share Posted March 17, 2013 The floor pan is actually a good ground. No need to change it. Although once you do your big 3 and ground to the frame. You want to ground to the amps or rear batteries to the frame to make a complete path For 4k I do recommend getting the biggest alt you can find/afford. And upgraded front batt and rear batt. 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head. Link to comment Share on other sites More sharing options...
Trey_Dog650 Posted March 17, 2013 Report Share Posted March 17, 2013 Where's the easiest wat to get to the frame in the rear of the car? Drill a hole through the floor and use a grommet and pass wire through 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head. Link to comment Share on other sites More sharing options...
Avery Howell Posted March 17, 2013 Report Share Posted March 17, 2013 Where's the easiest wat to get to the frame in the rear of the car? Same way you would pass a wire thru the firewall. 2012 Jeep Wrangler 3.6 W/ 6 Speed Build Log 2011 Ford F-150 SVT Raptor 6.2 Build Log YouTube Link to comment Share on other sites More sharing options...
