Max1636 Posted March 17, 2013 Report Posted March 17, 2013 I'm buying a new sub, a SoundStream XXX 18" and will be using my Fi SP4 for a home theatre setup. The amp I want to use is a Crescendo BC5500, is it a good match for the sub? Also what kind of electrical will I need, this is what I have: 1 x 225 Amp Upgraded Alternator 1 x Optima BlueTop 800CCA Starter 1 x Optima YellowTop 750CCA Deep Cycle 1 x Power AGM 1000CCA Deep Cycle - Big 4 Upgrade (Old Car) 1995 Volkswagon Golf MK3 2.0L: Fi SP4 18 On A DC Audio 3.5K In A PWK Box Hertz DSK 6" Speakers, Clarion HU 3x Fullriver 120aH AGM's, 225A Alt 2012 Subaru BRZ: Audison Prima APK 163 Bit One, Rockford Amps, Audison Sub
Vito Basser Posted March 19, 2013 Report Posted March 19, 2013 Damn, you get Crescendo in OZ? I hope it's on it's way to the UK! Do you have a volt meter up front to plumb in at the +ve terminal? I'd say you should be OK but keep an eye on it. I ran 2x SAZ-2500D's on less for over a year with no trouble at all... What ohm load are you looking at?
