Is a kerf beneficial?
What are the benefits of a kerf subwoofer enclosure? Would you compensate the length of the wood cuts on the front, back, and sides for the curves if the dimentions are intended for a rectangular box?
King dingalingIts not finished till i say so Bit@^!
Yesterday the dimensions of your box were looking bad (if were posted correctly), also didn't tell how subs an port were aimed.
Anyways port kerfing increases port efficiency just as aero port flares do, kerfing elsewhere has little or no effect on performance. When you calc your box, you add as displacement the loss of internal volume all kerfs cause.
Kerfs are hard to do and if you use proper port area chances are you won't need them at least in daily box projects.
  • Who's Online   1 Member, 0 Anonymous, 1314 Guests (See full list)
