AQ sdc 12' box
I picked up a set of AQ sdc2.5 12'' from AQ and they told me todo a box of 4cf net with 64'' of port and tune to 38hz .... i have put all the info into torres and cant seem to get it right.... what i have to work with is---16'tall 41'wide 18'deep for space subs and port back in a 2gen explorer... any help on this would be nice... would tuning to 34/35hz be better for me i will be runing them on a a DB drive pd2000.1
Here is a suggestion port driver's side:
Enclosure Specifications:
Fb = 35 Hz
Vb = 4 ft^3
External Height = 18 in
External Width = 37 in
External Depth = 18.125 in
Port Height = 4 1/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 37 x 18 1/8
Left & Right Sides =
Side 1 = 11 5/8 x 16 5/8
Side 2 = 15 3/4 x 16 5/8
Front & Back = 37 x 15 3/4
L Port Internal Assembly Parts:
Side to Side = 26 3/4 x 15 3/4
Assembly guide (generic dimensions):
Important notes:
- The port needs 4 1/8" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Thanks alot Joe X.........going to try this box out this week and see how the AQ subs sound,,,,,
There has been a change in the box to port to the driver's side, it is suitable for your vehicle but if you want port back then I would likely need to do a folded port which is less efficient.. let me know if you want me to try that.
Here is a T shaped port version, subs up/port back:
Fb = 35 Hz
Vb = 4 ft^3
External Height = 17 in
External Width = 41 in
External Depth = 18 in
Port Width = 4 3/8 in
Cut Sheet List:
2 x Top & Bottom (3 parts) = 41 x 18
Left & Right Sides = 16 1/2 x 14 3/4
2x Front = 18 5/16 x 14 3/4
Back = 41 x 14 3/4
Shared Port Internal Assembly Parts:
2 x Front to Back = 14 5/16 x 14 3/4
2 x Extension = 9 3/4 x 14 3/4
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- The port needs 4 3/8" of free airspace in front of it for proper operation.
  • Who's Online   1 Member, 0 Anonymous, 1212 Guests (See full list)
