just1moreamp Posted March 22, 2013 Report Share Posted March 22, 2013 I picked up a set of AQ sdc2.5 12'' from AQ and they told me todo a box of 4cf net with 64'' of port and tune to 38hz .... i have put all the info into torres and cant seem to get it right.... what i have to work with is---16'tall 41'wide 18'deep for space subs and port back in a 2gen explorer... any help on this would be nice... would tuning to 34/35hz be better for me i will be runing them on a a DB drive pd2000.1 Link to comment Share on other sites More sharing options...
just1moreamp Posted March 23, 2013 Author Report Share Posted March 23, 2013 No help,,,,,,,,,,,,,,,,,o well............... Link to comment Share on other sites More sharing options...
just1moreamp Posted March 23, 2013 Author Report Share Posted March 23, 2013 ttttttt Link to comment Share on other sites More sharing options...
Joe X Posted March 23, 2013 Report Share Posted March 23, 2013 Here is a suggestion port driver's side: Enclosure Specifications:Fb = 35 HzVb = 4 ft^3External Height = 18 inExternal Width = 37 inExternal Depth = 18.125 inPort Height = 4 1/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 37 x 18 1/8Left & Right Sides =Side 1 = 11 5/8 x 16 5/8Side 2 = 15 3/4 x 16 5/8Front & Back = 37 x 15 3/4L Port Internal Assembly Parts:Side to Side = 26 3/4 x 15 3/4 Assembly guide (generic dimensions): Important notes:- The port needs 4 1/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
just1moreamp Posted March 24, 2013 Author Report Share Posted March 24, 2013 Thanks alot Joe X.........going to try this box out this week and see how the AQ subs sound,,,,, Link to comment Share on other sites More sharing options...
Joe X Posted March 24, 2013 Report Share Posted March 24, 2013 Thanks alot Joe X.........going to try this box out this week and see how the AQ subs sound,,,,, There has been a change in the box to port to the driver's side, it is suitable for your vehicle but if you want port back then I would likely need to do a folded port which is less efficient.. let me know if you want me to try that. Link to comment Share on other sites More sharing options...
just1moreamp Posted March 24, 2013 Author Report Share Posted March 24, 2013 Is there anyway i can use -6''pvc ports for this box,,,,i would like subs and port back... i have 3-of the AQ2.5 12'' subs would love to run all 3 of them,,, Link to comment Share on other sites More sharing options...
Joe X Posted March 24, 2013 Report Share Posted March 24, 2013 Here is a T shaped port version, subs up/port back: Enclosure Specifications:Fb = 35 HzVb = 4 ft^3External Height = 17 inExternal Width = 41 inExternal Depth = 18 inPort Width = 4 3/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 41 x 18Left & Right Sides = 16 1/2 x 14 3/42x Front = 18 5/16 x 14 3/4Back = 41 x 14 3/4Shared Port Internal Assembly Parts:2 x Front to Back = 14 5/16 x 14 3/42 x Extension = 9 3/4 x 14 3/4 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- The port needs 4 3/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
just1moreamp Posted March 25, 2013 Author Report Share Posted March 25, 2013 I like that box alot,,,, Link to comment Share on other sites More sharing options...
just1moreamp Posted March 25, 2013 Author Report Share Posted March 25, 2013 Joe X Do you think i have the room to run all 3 of the AQ2.5 12'' subs that i have,,,,,,,,,,41''wide 16''tall 22''deep do i have room to run all 3 useing areo ports subs and ports back.... let me no what you think.. Link to comment Share on other sites More sharing options...
