2 Hdc3 15 Box Design Help
bgowdy31
12-16 on slot ports. Areos you can have a smaller port. The reason i asked about the coils is they cool different. Your current box is probly good just needs more port. With you running more then rms to them they need a smaller box to control the cone better. Can you give me all the dim. To you current box? W,L,H and the length of the areos.
ok so, my current box dimensions are as followed:
L= 35 3/4 in
H= 23 3/4 in
w= 27 1/4 in
Due to it being double plate all the way around its roughly 9.5 before displacement. i was off before because that was off a guess.
99 HONDA ACCORD EX COUPE
1 American Bass HD15-D1 ~ THE PLAN- ? CUBES NET ~ TUNED 36HZ
SOUNDSTREAM TA1.3K @ .5OHM DAILY ~ STOCK ALT ~ BULLZ AUDIO 1/0
~BEST SCORE TO DATE ~ 95 BLAZER 147+DB 30-SEC MUSIC-BB2400 & 1 HDC3-18 W/STOCK ELECTRICAL~
~01 HYUNDAI SANTE FE ~ 1 DC XL 18 ~ SHARK2500 @ .5 DAILY ~ 145.8 LEGAL~
~2010 FCBC 450 STREET 3RD OVERALL~
~2011 FCBC 450 STREET CHAMPION~
~YOUTUBE SEARCH->bgowdy31 & bgowdy3131~
Post your maximum dimensions for a box (height, width, depth) to see what can be done.
max dims: 10.57 cubes, thats pushing while factoring in the distance from aeros to hatch
L- 41 IN
H- 23 IN
W - 23 IN
How long is the ports in your box right now? What do you want your tuning to be on the new one?
about the same. its 41.5 right now with the port. i THINK they are 7.3 inches each
L- 41 IN
H- 23 IN
W - 23 IN
Well here is what you had:
L= 35 3/4 in
H= 23 3/4 in
w= 27 1/4 in
2 x 6" aero 7.3" long
1 1/2" all around
That box specs 8.8 cubes net @ 38.3Hz 56.6 square inches of port.
And here is a suggestion:
Enclosure Specifications:
Fb = 39.7 Hz
Vb = 9 ft^3
External Height = 23.5 in
External Width = 41 in
External Depth = 23.5 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 41 x 23 1/2
Left & Right Sides = 22 x 21 1/4
Front & Back = 41 x 21 1/4
Port Quantity and Dimensions:
Number of Ports = 4
Pipe Port Diameter = 6
Pipe Port Length = 17
This increases your port area which was low, since this is not 1.5" thick wood all around but just the baffle, you should use heavy threaded metallic bracing.
L- 41 IN
H- 23 IN
W - 23 IN
L= 35 3/4 in
H= 23 3/4 in
w= 27 1/4 in
1 1/2" all around
Fb = 39.7 Hz
Vb = 9 ft^3
Cut Sheet List:
Number of Ports = 4
so this is designed for sub up port back right? i cant see the image
Subs up/ four 6" PSP aeros back, bad thing you can't see the pic, try to visit the thread from another device.
yea im at work so it wont let my load it. i mean im figuring its subs up ports back, the 4 6"s would be along the bottom of the box side by side.
thanks for the help by the way man....
L- 41 IN
H- 23 IN
W - 23 IN
L= 35 3/4 in
H= 23 3/4 in
w= 27 1/4 in
1 1/2" all around
Fb = 39.7 Hz
Vb = 9 ft^3
Cut Sheet List:
Number of Ports = 4
quick question, whats the part mean where it says " 2 x Top & Bottom (3 parts) = 41 x 23 1/2 "? im not sure what it means by 2 parts
  • Who's Online   0 Members, 0 Anonymous, 931 Guests (See full list)
